Date/Time: Wed, 22 Jan 2025 20:49:11 +0000
Reduce number of stop loss etc. options on drop down menu in trade window- how to?
View Count: 593
[2018-10-23 16:30:19]
User686258 - Posts: 7
How can I keep things simple and de-select many of the stop loss options in the trade window.
Thank you
[2018-10-23 17:14:05]
If you are referring to Trade Window configurations, they can be deleted. Refer to:
Basic Trading and the Trade Window: Delete Configuration File
[2018-10-23 18:08:01]
As a specific example:
Suppose I use the drop down window in the trade window to look at my trading options.
There is a long list there.
Starts off with:
Limit
Market
Stop
Limit chase
etc.
If I simply want to remove "Limit chase" (for example) from that drop down list, how do I do that?
thank you again.
[2018-10-23 22:40:12]
You cannot reduce the list.
