Date/Time: Wed, 22 Jan 2025 21:00:13 +0000
DOM Rendering Errors
View Count: 620
[2018-10-23 15:39:30] |
User864893 - Posts: 26 |
Sometimes i find some rendering errors on the DOM. Please see the 1 at 1234.6 bid column; 1235.1 & 1235.2: bid column 1238.0 & 1238.1: ask column I have seen this errors from time to time also on previous releases: Currently using SC 1827; Connect to GAIN http://www.sierrachart.com/image.php?Image=1540308894420.png |
[2018-10-23 20:31:28] |
We do not think we can do anything to solve this. Every time we try we always create a new problem. There is evidence of a previous fix for this which was later removed. For a reliable data feed you need to use the Sierra Chart Exchange Data Feed instead: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
