Date/Time: Wed, 22 Jan 2025 21:01:03 +0000
Entry efficiency
View Count: 1165
[2018-10-23 15:23:11] |
User877753 - Posts: 152 |
Hello, Some issue with Entry Efficiency in the activity Log (SC 1825) : Entry Efficiency is 100% for all my trades (which is wrong). Exit Efficiency and Total Efficiency seem correct. Thanks for your help. JM |
Attachment Deleted. Private File |
[2018-10-23 17:49:10] |
At the start of a new position, the entry efficiency will be 100%.
[2018-10-23 18:35:25] |
So what is the purpose of the Entry Efficiency, if always @ 100% (or 0%)? Can you help me to understand : see the screenshot attached ? Thank you for your help. Regards JM Date Time Of Last Edit: 2018-10-23 18:35:55
activ log multi trade.png / V - Attached On 2018-10-23 18:35:15 UTC - Size: 38.99 KB - 279 views |
[2018-10-24 00:53:09] |
We do see what appears to be a problem. We will look into it today.
[2018-10-24 09:29:18] |
We are not able to reproduce any problem with the Entry Efficiency. We want you to test the next release when it comes out.
[2018-10-24 12:20:07] |
Same issue remains with 1828.
[2018-10-24 23:40:20] |
Could you select the lines where the entry efficiency appears to be wrong and then select Edit >> Copy Selection and paste it here so we can look at them more clearly. We will then see if we can reproduce this or explain this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-24 23:40:21] |
Could you select the lines where the Entry Efficiency appears to be wrong and then select Edit >> Copy Selection and paste it here so we can look at them more clearly. We will then see if we can reproduce this or explain this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-24 23:40:37
