Date/Time: Wed, 22 Jan 2025 21:01:42 +0000
Data Feed
View Count: 606
[2018-10-23 15:19:48] |
User288945 - Posts: 22 |
I connected to CQG in the global settings. I lost my data feed from SC. My understanding is that I would receive live data from SC not CQG, What am I doing wrong?
[2018-10-23 17:12:33] |
If Sierra Chart is connected to CQG, make sure you are using the CQG symbols. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices (Integration with Trading Services) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-23 17:13:16
