Date/Time: Wed, 22 Jan 2025 20:56:35 +0000
Data Feed
View Count: 662
[2018-10-23 13:15:55]
User288945 - Posts: 22
I just connected to CQG in SC. When I did I lost my data feed from SC. I have been trying to set up my Data feed from SC and trade through Optimus and AMP. What do I need to do?
[2018-10-23 17:22:51]
tesseract353 - Posts: 66
This sounds like user error.
You should first verify that you have set everything up properly per the Setup Instructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
This next link addresses a common mistake that you may be dealing with:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices
[2018-10-23 20:01:20]
You need to be sure to use the CQG symbols as explained here:
[2018-10-24 11:59:03]
I have looked at everything you have sent me and tried everything recommended. This is what I can see.
There is no M by the symbol.
I appear to be getting a live Forex feed on EURUSD.
What I need is S&P 500 cash, S&P 500 E mini, EURUSD to start, other symbols can come later.
[2018-10-24 16:17:15]
A solution was found with Optimus. It was understood that the full CME package included the cash index. Apparently, It doesn't and we had to add the indices for an additional $3.25.
[2018-10-24 17:25:12]
Yes, that is correct. Refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CashIndexes
Are you now receiving real-time data though for the S&P 500 mini futures?
If not tell us the symbol of the chart and follow the instructions here:
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
