Date/Time: Wed, 22 Jan 2025 23:59:47 +0000
Referencing Chart Drawings
View Count: 1518
[2018-10-23 11:27:17] |
infpz - Posts: 826 |
Using Color Background Based On, Is there syntax that results in the background highlighted when the price crosses anywhere along the slope of the non-horizontal drawn line? I am trying to get a result when the market crosses a trendline - often this happens before it crosses the anchor price. Possible?
[2018-10-23 17:10:26] |
Yes. Refer to: Study/Chart Alerts And Scanning: Referencing Chart Drawings Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-29 16:04:40] |
How would we designate the condition if the market crosses the line anywhere between the anchors, rather than just the anchor itself? We tried this but we unsuccessful: CROSSOVERFROMABOVE(C, UDID[3].[A1:A2])
[2018-10-29 22:00:31] |
John - SC Support - Posts: 37420 |
Unfortunately, there is no automated way to be able to use a drawing with a CROSSOVER function. The only option available would be to enter the drawing data into a spreadsheet and then use that to determine line coordinates that could be fed into the CROSSOVER function.
