Date/Time: Wed, 22 Jan 2025 20:52:23 +0000
Alert Not Triggering for 'High/Low for Time Period'
View Count: 694
[2018-10-23 08:37:26]
User465507 - Posts: 74
I've setup this study with the alert condition "=OR(CROSSFROMBELOW(C, SG1), CROSSFROMABOVE(C, SG2))"
I'm not sure where I've gone wrong because it isn't triggering whenever price makes a new high or low through the line. I've noticed that the study readjusts the high/low line as soon as price moves up so does that mean that price never actually crosses the line? Or should it trigger an alert and then readjust the high/low?
I've attached screenshots of my settings.
Any ideas on where I should look or what I should do to get it working?
imagesetting1.png / V - Attached On 2018-10-23 08:36:25 UTC - Size: 28.04 KB - 246 views
imagesetting2.png / V - Attached On 2018-10-23 08:36:28 UTC - Size: 18.07 KB - 250 views
[2018-10-24 23:42:23]
What you are trying to do will not work in this case, because, as you state, the High/Low will keep adjusting, therefore the Closing price never actually crosses over the High/Low.
It sounds like you are wanting to be notified if there is a new High or Low reached on the current bar. If this is the case, then refer to the following study:
New Daily High/Low Alert
