Date/Time: Wed, 22 Jan 2025 20:39:36 +0000
conditional formatting on the sheets
View Count: 635
[2018-10-23 04:22:44] |
User852086 - Posts: 41 |
How do you configure conditional formatting on the Spread sheets? Say, I would like the cell to turn green when the number is positive and red when negative? I'm using the regular sheet to compute the numbers from other sheets and try to implement some sort of color codding. |
[2018-10-23 08:22:44] |
This is not supported.
