Date/Time: Thu, 23 Jan 2025 00:00:31 +0000
zig zag and text are moved off the bar chart.
View Count: 1058
[2018-10-23 01:28:24] |
User256311 - Posts: 11 |
all my texts and zig-zag automatically move off the bar chart. it is best illustrated in the attached photo. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=23036 |
[2018-10-23 03:21:28] |
Refer to the documentation here: Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region You need to check the Scale Range for the study and the main price graph and make sure they are both Automatic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 03:22:48
[2018-10-31 02:39:28] |
Hello, I have been adjusting the scaling settings and price graph with no success. I have also noticed when zoom out you can see texts and drawings from other symbols. please find attached screenshot. may I please request further guidance as it is difficult to swing trade when the trend lines,zig zag and text move. |
Screenshot (23).png / V - Attached On 2018-10-31 02:33:03 UTC - Size: 424.12 KB - 271 views |
[2018-10-31 21:23:12] |
Ultimately what you are doing is complicated and confusing and would be an additional cost for us to look this over by getting the Chartbook and advise on the solution. I have also noticed when zoom out you can see texts and drawings from other symbols. please find attached screenshot. Chart Drawing Tools: Showing or Hiding Drawings for Different Symbols Also Post #2 has been updated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 21:23:57
