Date/Time: Wed, 22 Jan 2025 20:54:20 +0000
Time and Sales filters and alerts in different base unit
View Count: 628
[2018-10-22 23:52:46] |
abn2609 - Posts: 15 |
Settings > Filtering/Highlight & Alert Example products: BTCUSD-BitFinex ETHUSD-BitFinex Probably all BitFinex. So the trades are shown in their respective coins, which matches the exchange, that is fine. But the filters do not appear to be working, or may be in some other "base" unit. E.g. If I put a filter of volume >= 10, why am I still seeing all these trades worth less than 10? Same goes for alerts. The base unit appears to be different to the print, when it should be the same. Please look into why this is the case. |
[2018-10-23 03:46:32] |
The reason for this is because internally the volume values have a value 10,000 times higher than you see. We are working on just representing these trade volume/quantity values as integers only even when displayed. But that may be about three months away. The filtering settings can only work with integer values. For 10 you would need to use a value of 100000. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-23 03:47:01
