Date/Time: Sun, 24 Nov 2024 12:49:41 +0000
layout template
View Count: 2145
[2013-10-30 14:25:14] |
User51517 - Posts: 58 |
hello, is there a way to save my charting layout template to include not only my studies, but also graphic settings? thanks |
[2013-10-30 15:26:33] |
Sierra Chart - Max - Posts: 5730 |
To do this you will need to disable Global Graphics Settings for each chart, as is explained here: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html#Intro For more information about Chartbooks, refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html Sierra Chart Support |
[2013-10-30 15:33:02] |
I did disable global graphic settings for each chart. I originally thought saving my chart as study collection would do the trick, but it turns out it only saves the studies, not graphic setting. I still have to manually set each chart. Probably you could add this feature quickly if it's not too hard engineering? |
[2013-10-30 17:55:53] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/helpdetails20.html There are no further features planned. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
