Date/Time: Wed, 22 Jan 2025 20:38:19 +0000
Trade Activity log not showing currency 1825
View Count: 621
[2018-10-22 16:35:40] |
User942837 - Posts: 108 |
When I update trade activity log to show currency and points - it just shows Points,Points. Can you kindly tell me what is wrong please? Date Time Of Last Edit: 2018-10-22 16:36:25
2018-10-22_18-34-57.png / V - Attached On 2018-10-22 16:35:25 UTC - Size: 20.38 KB - 258 views |
[2018-10-22 19:34:08] |
This is because the symbol uses a single digit year and the symbol settings are for a two digit year. So there are no known symbol settings for that existing Trade Activity data after the conversion to two digit years by Gain Capital. At this point we do not have a solution. We have to think about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-22 20:21:18
[2018-10-23 07:31:01] |
On demo account with 2 digit year it is showing the right values for currency. thank you |
[2018-10-23 08:28:59] |
Yes that does make sense.
[2018-10-23 19:40:03] |
Are you working to fix it on the live ac? Thanks |
[2018-10-23 21:04:44] |
Yes we will implement a solution.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-23 21:05:10
[2018-10-25 00:04:54] |
This will be solved in 1829 coming out later today.
