Date/Time: Wed, 22 Jan 2025 20:42:56 +0000
last candle bar drops to zero in my historical chart
View Count: 580
[2018-10-21 22:42:37] |
User517452 - Posts: 27 |
Hi, The last candle bar drops from last close price to zero in my historical chart for many symbols. Could you tell me how to set it correctly so I don't see the wrong bar. See attached screen shot. BTW, I use IB as data source with "allow support for SC data feeds" checked. Date Time Of Last Edit: 2018-10-21 22:44:35
Capture.PNG / V - Attached On 2018-10-21 22:41:54 UTC - Size: 34.7 KB - 229 views |
[2018-10-22 11:25:03] |
Refer to: Interactive Brokers Trading Service: Current Daily High and Low for Forex Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-22 11:25:05] |
