Date/Time: Sun, 23 Feb 2025 14:46:17 +0000
[User Discussion] - bar back-testing using multiple charts
View Count: 814
[2018-10-21 17:53:32] |
User30743 - Posts: 365 |
how do i perform bar based backetest for an acsil aos using multiple charts? it seem like it is possible only to perform manual replay backtest when using multiple charts. - and it terribly slow. also, is there any way to skip overnight session when performing these backtest? i dont know what i am doing wrong, but even though i dont use overnight session in the chart (there are no candles visible for night) it seems like it is stucked there and performing tests.. |
[2018-10-21 18:06:50] |
This is not supported. For your other question, refer to: Replaying Charts: Automatic Skipping of Periods Where There Is No Trading and Synchronization Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-17 21:15:25] |
still not supported autobeckesting on multiple charts?
