Date/Time: Wed, 22 Jan 2025 20:54:55 +0000
Scale text color
View Count: 646
[2018-10-20 19:15:52] |
User517452 - Posts: 27 |
I changed the chart text color to white, and saw all Y scale text color is white, but the month and year of X scale text color is black with white background. This makes the chart looks ugly, since the chart background is black and partial of the x scale text has white background. Can I make all the X scale text color to the same as Y scale text color (white foreground, black background for month, year)?
Date Time Of Last Edit: 2018-10-20 22:31:58
capture.png / V - Attached On 2018-10-20 22:31:44 UTC - Size: 53.02 KB - 263 views |
[2018-10-21 09:00:05] |
You need to uncheck this Chart >> Chart Settings option for the chart: Chart Settings: Highlight Timescale Dates, Months and Years (Chart >> Chart Settings >> Scale menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-21 09:01:01
[2018-10-22 04:07:24] |
I did as your instructed, Months on the time scale are not highlighted, but Years are still highlighted.
[2018-10-22 20:36:36] |
User750920 - Posts: 280 |
Can the color for this (if Highlighted is checked) be changed in the Global settings independent of the Scale color? If so which setting.
Date Time Of Last Edit: 2018-10-22 20:49:05
