Date/Time: Wed, 22 Jan 2025 20:46:51 +0000
Same volume bar and price bar width
View Count: 943
[2018-10-20 04:13:39]
User517452 - Posts: 27
Can we set volume bar width and price bar width the same?
[2018-10-22 18:21:40]
John - SC Support - Posts: 37407
Yes. Refer to Graphics Settings for the OHLC bars - Bar High/Low Down and Bar High/Low Up, starting here and the next entry: Graphics Settings: Bar High-Low Down
Set these to the same width as the Subgraph Width setting for the Volume bars. Refer to the documentation for the Width of a Subgraph here: Chart Studies: Subgraphs Tab >> Line Width
[2018-10-23 02:58:41]
No sure if we understand each other correctly. For a candle bar (price bar), its width changes with zoom, so I want the corresponding volume bar's width change accordingly to keep the same with as the candle bar. Can we do it?
[2018-10-23 03:21:58]
Okay we understand, no this is not supported.
