Date/Time: Wed, 22 Jan 2025 18:08:35 +0000
GAIN Capital Connection Issue
View Count: 666
[2018-10-19 23:29:03] |
User420178 - Posts: 1 |
I try toaday to use it with data from GainCapital OEC, but nothing to do, always error... what's wrong ? Thanks GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2018-10-20 00:54:21 GAIN Capital FIX Trading socket (1) | Creating socket. | 2018-10-20 00:54:21 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2018-10-20 00:54:21 GAIN Capital FIX Trading socket (1) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2018-10-20 00:54:28 * |
[2018-10-19 23:42:38] |
Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ServerAvailability Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
