Date/Time: Wed, 22 Jan 2025 23:19:55 +0000
Running P/L not calculating correctly
View Count: 1871
[2018-11-02 02:43:10] |
but I want to be able to see what trades are open and what my total p/l is in one place just like you had it. Actually what we think is best for you to use is the Trade Stats for Charts tab. This is what this was meant for:Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab If that does not give you what you want. Let us know and we will see if there is any anything we need to add or resolve. We are going to get the changes out by Monday so we think it is best just to wait until then rather than referring you to a prior version. Right now, it looks like the "Running P/L" column should be labeled "Just a Bunch Of Numbers". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-02 02:45:45
[2018-11-02 02:50:14] |
User612649 - Posts: 40 |
Ahhhhh. Trade Stats for Charts....... Nice. Thanks for educating me. That will work. Appreciate the quick response.
