Date/Time: Wed, 22 Jan 2025 18:14:08 +0000
Caught an exception during the processing of a timer event
View Count: 700
[2018-10-19 09:19:38] |
anpy - Posts: 35 |
I’m running the SC trial connected to Bitmex. Every few days, I get the following error: Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-19 10:27:51 * After the error has occurred once, it's not possible to get rid of it even after restarting the computer. The only thing that helps is to open a backup of the chartbook...which works until the error appears again after some time. - SC 64-bit, tried stable, pre-release and second SC installation - no custom studies/code thanks in advance |
[2018-10-19 23:18:54] |
When you have this issue provide us the Chartbook you are using by following these instructions and we will see if we can reproduce the problem: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
