Date/Time: Wed, 22 Jan 2025 18:15:17 +0000
Couldn't downloade data from TdAmeritrade
View Count: 547
[2018-10-19 01:37:31] |
User490625 - Posts: 3 |
To Whom It May Concern: I couldn't download data from TdAmeritrade today. It worked well yesterday. I didn't change anything. Would you please to check what's wrong with it? Thanks. Roger Sun |
[2018-10-19 02:45:00] |
Refer to this thread here: TD Ameritrade Data Not Working and Fix Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
