Date/Time: Wed, 22 Jan 2025 18:06:43 +0000
Average True Range
View Count: 737
[2018-10-18 17:09:18] |
User750920 - Posts: 280 |
Is there a study where I can have a multiple of the ATR. Say 2 times the ATR and then plot it as a line. Thanks |
[2018-10-18 22:23:21] |
Yes. Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
