Date/Time: Wed, 22 Jan 2025 18:04:24 +0000
horizontal line tool
View Count: 588
[2018-10-18 16:33:38] |
User806639 - Posts: 32 |
Is it possible to put two separate horizontal line tools on the same control panel and have them make different color lines on the chart. I am attempting to have one for the support line and a separate one for the resistance line. |
[2018-10-18 22:22:49] |
Yes. Refer to: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
