Date/Time: Wed, 22 Jan 2025 18:22:55 +0000
Bars to the Right
View Count: 713
[2018-10-18 14:56:22] |
User506372 - Posts: 2 |
How do I add space between the most current bar at the hard right edge of the chart and the edge of the chart itself. When I use the mouse scroll wheel I can position the bar away from the edge but it just fills back in when the next bar prints. I've searched the chart settings but to no avail. Please help. I can't stand the bar touching the edge of the chart. It is visually disturbing to me.
[2018-10-18 15:25:47] |
Xfanman1 - Posts: 320 |
Chart/Lock Fill Space menu item. -- Scott |
[2018-10-18 15:29:18] |
Awesome. Thank you! I knew there had to be an easy way...
[2018-10-18 22:42:47] |
Here is the relevant documentation for this: Working With Charts: Scrolling The Chart and Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
