Date/Time: Wed, 22 Jan 2025 19:29:14 +0000
Candlestick Wick Sizing?
View Count: 1511
[2018-10-17 20:20:17] |
macguerra - Posts: 20 |
Anyone know how, if possible, to increase the size of the candlestick wicks? (Candlestick Outline Width Size does not affect the wick itself.) Thanks, |
[2018-10-17 21:15:34] |
You need to change this graphics setting: Graphics Settings: Bar High-Low Down And the one underneath it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-17 21:15:41
