Date/Time: Wed, 22 Jan 2025 19:28:55 +0000
Chart Study Window resizing
View Count: 1032
[2018-10-17 19:56:38] |
samual sprat - Posts: 343 |
Hi, I have a couple of study collections with a large number of studies in it. When I manually name some of the studies using short name, in the main Chart Studies window it can causes the text in the Studies to Graph pane to be very long. It can be very time consuming to do tasks like find a study within the collection that may be misbehaving and causing high latency on the chart. Reason is you have to use the horizontal scroll bar to scroll right to check 'XXX ms' values and then page down and left to read the name of the next group of studies, scroll right again, etc. Would be great to be able to resize the Chart Studies window, is this something support can look into at some point? Thanks S |
[2018-10-17 20:55:06] |
Possibly but this will not be until sometime next year when the dialog windows get redeveloped.
