Date/Time: Wed, 22 Jan 2025 19:20:02 +0000
chartbook sharing
View Count: 1270
[2018-10-17 19:08:15] |
User888458 - Posts: 17 |
I received a file from another Sierra user, but it doesn't appear as one of my files when I reopen Sierra. I think I followed all the instructions and am not in Safe Mode. I see the file name in Account Control Panel, though, as if I have it.
[2018-10-17 20:46:05] |
So you do not see it listed in File >> Open Chartbook? If not, then restart Sierra Chart and force the login: Sierra Chart - Software Login Instructions: Forced Login You should see messages in the Window >> Message Log indicating that the file is being downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-17 20:46:14
[2018-10-18 14:43:35] |
Okay...thanks, now I got it....but wrong symbol so it doesn't open. I have to figure out how to change the symbol
[2018-10-18 15:39:00] |
Sierra Chart - Max - Posts: 5779 |
Refer to the Changing the Symbol of a Chart documentation here: Changing the Symbol of a Chart Sierra Chart Support |
