Date/Time: Sun, 24 Nov 2024 10:39:14 +0000
keeping strategy testing separated
View Count: 1383
[2013-10-29 19:33:20]
User021827 - Posts: 174
hi
I have 2 autotrade strategies in 2 different chartbooks running on crude.
How do I keep those separated ?
It seems the position from 1 shows on the other chart. And I dont think the trade activity log is separated either.
How do people keep things separated ?
shane
[2013-10-30 01:12:52]
You cannot if they are for the same symbol. You need to use 2 separate copies of Sierra Chart. And in the case of live automated trading, you have to use separate trade accounts.
[2013-10-30 01:36:50]
hi
thank you for the info
Then autotrade strategies are tied to symbol and not to the chart ?
thank you
shane
[2013-10-30 02:08:23]
Yes.
[2013-10-30 02:52:40]
shane
