Date/Time: Wed, 22 Jan 2025 19:27:09 +0000
Study to display total movement for day in ticks?
View Count: 700
[2018-10-17 15:51:59] |
jaxscott - Posts: 57 |
Is there such a study in SC that displays the total # of ticks that an instrument has moved in a day? Not the range which tells me the difference between the high and low of the day, but the distance up and down that it has traveled. For instance, the NQ moved 1176 ticks on Tuesday. The ES moved 294 ticks...
[2018-10-17 18:55:57] |
This can be done by using the Daily OHLC study and using the Study Subgraphs Subtract study to calculate the difference between the high and the low and then use the Study Subgraph in Ticks study to calculate the difference. You can find the documentation here: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php We will be adding documentation for the Study Subgraph in Ticks study today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
