Date/Time: Wed, 22 Jan 2025 19:19:51 +0000
multi account
View Count: 613
[2018-10-17 15:29:36] |
User156117 - Posts: 2 |
Good afternoon, I need to sit on several Bitmex accounts. After reading your instructions, I want to ask a few questions. 1 - To sit for example on 5 Bitmex accounts, do I need to install your program 5 times separately? 2 - to sit simultaneously on 5 accounts is enough for me a standard package? 3 - to sit on 5 Bitmeks accounts, do I need to enter the same username and password of the siera chart for 5 accounts? |
[2018-10-17 20:41:19] |
1. Yes because the way BitMex handles multiple accounts this is absurdly complex. 2. Yes. 3. Yes. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
