Date/Time: Wed, 22 Jan 2025 20:51:05 +0000
Custom market sessions
View Count: 647
[2018-10-17 15:26:34] |
User465507 - Posts: 74 |
I can see I can create up to two custom sessions for any product using day & evening session. Is it possible to create more sessions? This might be used in very niche cases so assume not - but maybe with your custom programming language? It's use case would be for multi-leg spreads from different exchanges where you might want to have more than one session (day, overnight, and other non-synced opens and closes). |
[2018-10-17 16:31:59] |
User750920 - Posts: 280 |
It would also be useful for currencies. Three session profiles per day (One for Asia open-close, One for Europe open-close and One for US open-close).
Date Time Of Last Edit: 2018-10-17 16:33:44
[2018-10-17 17:08:36] |
No, this is not supported.
[2018-10-21 20:56:54] |
Fair enough. It would be a cool feature to have, especially if you plan on building out more spread functionality in the future.
