Date/Time: Sun, 24 Nov 2024 10:28:29 +0000
DOM.....
View Count: 1254
[2013-10-29 19:26:34] |
User57751 - Posts: 1 |
why on the chart dom is there only 5 depth of market numbers? CTS has 10 on each side?? (buy and sell) ...if you are tape reader...this is MANDATORY...... what happened in this new update? thank you? |
[2013-10-29 19:41:29] |
This was reduced to 5 to minimize bandwidth for the time being until CTS can work out some efficiency issues with the market data feed.
