Date/Time: Wed, 22 Jan 2025 19:06:00 +0000
[Programming Help] - Attaching control Bar to charts
View Count: 932
[2018-10-17 12:40:16] |
User942178 - Posts: 25 |
How do I attach the control bar to each of my charts so when I open a chart, the control bar is visible on that chart.
[2018-10-17 20:58:02] |
Refer to the documentation here for this: Control Bar: Window >> Control Bars >> Control Bar [1-12] And when creating a new chart, to have the same configuration as an existing one, refer to: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
