Date/Time: Wed, 22 Jan 2025 18:15:48 +0000
Log In
View Count: 570
[2018-10-16 22:17:20] |
vtvince - Posts: 3 |
I log-in, do I use SierraChart\SierraChart.exe or SierraChart\SierraChart_64.exe? What is the difference? When I downloaded SierraCharts, OI got both icons.
[2018-10-16 22:19:53] |
You can use either one. We recommend the one with 64 in it.
