Date/Time: Wed, 22 Jan 2025 19:27:18 +0000
Connection to Derebit?
View Count: 1264
[2018-10-16 19:44:36] |
DramaticFanatic - Posts: 12 |
Request to connect to Derebit
[2018-10-16 20:33:39] |
For market data, this is already supported. You will find the symbols in File >> Find Symbol >> Deribit. Make sure you update to the very latest pre-release. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-17 03:12:43] |
Thanks!! Perfect 👌🏻 is there is any way to get market depth more then 6 places deep?
[2018-10-17 03:44:55] |
All available market depth data is provided. For the BTC Perpetual contract, we see a lot more than 6 levels.
[2018-10-17 10:33:37] |
stabilo.boss - Posts: 2 |
Hi there, is it possible to trade on deribit through sierra? Thanks. |
[2018-10-17 21:18:24] |
No, not at this time.
