Date/Time: Wed, 22 Jan 2025 18:17:05 +0000
Copying Sierra Chart folder
View Count: 689
[2018-10-16 17:45:37]
User459170 - Posts: 262
If I copy my entire Sierrachart folder into another location, will that work as a second instance for backtesting purposes? Will there be any data conflict? Thanks.
[2018-10-16 18:22:06]
You need to follow the step-by-step instructions here for this:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System
