Date/Time: Thu, 28 Nov 2024 15:38:09 +0000
Limiting trading by number of futures contracts
View Count: 2424
[2018-10-16 15:16:40] |
User598006 - Posts: 8 |
Hello, Is it possible in Sierra Charts to limit the number of contracts I can trade at any particular time? I am looking to limit myself in the number of contracts I can trade actively. Please advise. Thank you, Adam |
[2018-10-16 16:22:40] |
tesseract353 - Posts: 66 |
If you are looking to impose an "Aggregate Limit" on the total number of contracts allowed to be open at one time, this can be accomplished a few ways. -Go to: Global Settings > Symbol Settings and check the box that says, "Use Global Trade Position Limit" and input your desired number contracts. -Check to see if your clearing firm offers the ability to impose an "Aggregate Limit" on you from their side. I know RCG can do this. -Requesting your margin requirements be raised. For example: $8,000 per contract. |
[2018-10-16 16:39:32] |
You Rock! That works like a charm!! Have a Great day! |
[2023-04-13 21:14:39] |
User509533 - Posts: 57 |
Does "Use Global Trade Position Limit" not work in the Sim mode?
[2023-04-13 21:46:15] |
From the documentation for this feature: This feature does not work properly when Sierra Chart Trade Simulation Mode is being used. It is only functional for non-simulated trading.
[2023-04-13 23:24:19] |
I am also assuming the feature that flat/lock account for the day based on daily loss limit will also work when I switch to live trading. Right?
[2023-04-14 14:18:42] |
The Global Profit/Loss Management works in both Live and Sim mode. Refer to the following: Global Profit/Loss Management: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
