Date/Time: Wed, 22 Jan 2025 18:10:38 +0000
Message Error?
View Count: 910
[2018-10-16 14:18:23]
User750920 - Posts: 280
Ever since I added the TICK-NYSE using the Add a symbol this error message pops up. It does not occur all the time - it seems to occur at start up and when I make a change to a study parameter (for example I checked the box to show the label on the Volume study). I also have the NISS-NYSE added too without issue.
Software version: 1806 64-bit | 2018-10-16 06:45:50
Usage end date: 2018-10-27 | 2018-10-16 06:45:50
Enabled for: Advanced Features. | 2018-10-16 06:45:50
Enabled for: Advanced Features 2. | 2018-10-16 06:45:50
Enabled for: Sierra Chart Historical Data Service. | 2018-10-16 06:45:50
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-10-16 06:45:50
Current selected Data/Trading service: GAIN Capital/OEC | 2018-10-16 06:45:50
Chart Update Interval: 500 | 2018-10-16 06:45:50
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-10-16 06:45:50
2018-10-16 06:45:50 Local computer time | 2018-10-16 06:45:50
2018-10-16 13:45:50 Local computer time in UTC | 2018-10-16 06:45:50
2018-10-16 06:45:50 Local computer time in SC Time Zone | 2018-10-16 06:45:50
2018-10-15 01:02:21 Server time in UTC | 2018-10-16 06:45:50
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-10-16 06:45:50
Program path: C:\SierraChart\ | 2018-10-16 06:45:50
Data Files path: C:\SierraChart\Data\ | 2018-10-16 06:45:50
OS Version Number: 6.1 | 2018-10-16 06:45:50
Locale Setting: C | 2018-10-16 06:45:50
GGCZ8 30 Min #18 | Reloading chart. | 2018-10-16 06:48:12
Chart #18 has tagged chart #11 for full recalculation. Chartbook: MIG.Cht | 2018-10-16 06:48:12
Chart #18 has tagged chart #12 for full recalculation. Chartbook: MIG.Cht | 2018-10-16 06:48:12
Chart #18 has tagged chart #6 for full recalculation. Chartbook: MIG.Cht | 2018-10-16 06:48:12
GGCZ8 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: MIG.Cht | 2018-10-16 06:48:13
GGCZ8 #11 | Performing a full recalculation because it has been tagged. Chartbook: MIG.Cht | 2018-10-16 06:48:13
GGCZ8 Aligned Renko 2t #6 | Performing a full recalculation because it has been tagged. Chartbook: MIG.Cht | 2018-10-16 06:48:13
ESZ8 30 Min #17 | Reloading chart. | 2018-10-16 06:49:39
Chart #17 has tagged chart #1 for full recalculation. Chartbook: MIG.Cht | 2018-10-16 06:49:39
Chart #17 has tagged chart #4 for full recalculation. Chartbook: MIG.Cht | 2018-10-16 06:49:39
Chart #17 has tagged chart #8 for full recalculation. Chartbook: MIG.Cht | 2018-10-16 06:49:39
ESZ8 Aligned Renko 2t #4 | Performing a full recalculation because it has been tagged. Chartbook: MIG.Cht | 2018-10-16 06:49:39
ESZ8 [CB] #1 | Performing a full recalculation because it has been tagged. Chartbook: MIG.Cht | 2018-10-16 06:49:39
ESZ8 5 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MIG.Cht | 2018-10-16 06:49:39
: Out of bounds array error at index 14751 | 2018-10-16 07:11:18 *
Array message repeat count limit reached. | 2018-10-16 07:11:18 *
[2018-10-17 17:47:06]
The problem is every time we try to reproduce an issue like this we cannot but we will try.
Attach the Chartbook you are experiencing this with by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2018-10-17 20:17:29]
Hi, I just wanted you to know I tested one thing. First the Chart in questions is the Chart Called ES Intraday (SC ESZ8 Aligned Renko 2t #4) As I mentioned before after I added teh TICK-NYSE the issue started. Also as an FYI I duplicated this chart to another chartbook without any other charts and the issue did NOT occur.
Thank you.
Private File
[2018-10-19 05:08:33]
We were able to reproduce the issue and it will be resolved in the next release. It related to the bid and ask price arrays not being increased in size for the additional symbol study.
