Date/Time: Wed, 22 Jan 2025 18:03:18 +0000
[User Discussion] - price centering of chart
View Count: 1430
[2018-10-16 13:08:26] |
User635423 - Posts: 51 |
Hello, Please show how to keep the moving price not the indicators to stay centered on the chart. Scrolling price back into view all day can be taxing. Thank you |
[2018-10-16 14:27:01] |
User750920 - Posts: 280 |
In the Chart Settings I think that would be the Constant Range Scale Mode. I use it on my Numbered Bars chart as the price gets toward the top or bottom of the scale is will auto adjust so the current price re-centers.
[2018-10-16 21:17:39] |
You do need to set the Scale Range to Constant Range; Chart Scale and Scale Adjusting: Scale Range (Scale Settings) If you want the price to stay fixed regardless of where you are scrolling, then get the Scales displayed as you desire and then right click in the Scales and select Scale Range: User Defined with Auto Set. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-16 21:56:04] |
Question. If you use User Defined with Automatic Zero-Based isn't the User Defined Top and Bottom of range a fixed price? If so once price exceeds the top or bottom what happens.
