Date/Time: Wed, 22 Jan 2025 18:21:01 +0000
Server side OCO order
View Count: 1841
[2018-10-16 04:31:22] |
User459170 - Posts: 262 |
If I place a Server Side OCO order, will I have control over the attached stop orders? Can they be altered after submission? Thanks.
[2018-10-16 07:12:18] |
Yes this is supported.
[2018-10-16 07:12:20] |
Yes this is supported. Also if you could not modify an order, then server-side OCO would not be supported at all with the particular service that does not allow that. That would make it totally unacceptable.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-16 07:23:04
[2018-10-16 16:47:00] |
Thank you so much. Please confirm if my understanding is correct. If I placed an OCO order with 2 lots and it got executed. Lot 1 has a target order X, but for the 2nd lot, I want to manually trail and I have a stop loss order Y for it. If I use Server OCO order and say Lot 1 reaches target and order X is executed. Now stop loss order Y is resting on the server for the second lot. Can I keep moving Y as price moves? Thanks so much for your help. |
[2018-10-16 18:01:29] |
Yes but we see you are using CQG. Update to the latest prerelease to avoid using CQG server-side bracket orders which are no longer supported and have problems. Here are instructions: Software Download: Fast Update Server-side OCO orders are still supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
