Date/Time: Wed, 22 Jan 2025 18:09:52 +0000
Crosshair not appearing on both charts when using window always visible
View Count: 956
[2018-10-16 03:35:25] |
Willson - Posts: 176 |
Using Ver 1815. When using "Windows Always visible" the cross hair Does not track/display on both windows simultaneously as I recall that it did some versions back. That feature is very useful. Is there a method to display crosshair on both windows with tracking?
[2018-10-16 21:10:05] |
This is not supported. The documentation for the Global Cursor is here: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
