Date/Time: Sun, 24 Nov 2024 11:04:32 +0000
Stocks and Futures
View Count: 1251
[2013-10-29 16:02:46]
Sierra Chart - Max - Posts: 5730
CTS T4 is a supported Trading platform. For more information, please see:
http://www.sierrachart.com/index.php?l=doc/CTS_T4.php
If only Historical Data for stocks is required, then you can use the "Sierra Chart Historical Data Service" which is included with packages 3 and 5:
http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html
For Real-Time stock data, you will need to select a supported Data/Trading service that provides stock data or trading:
http://www.sierrachart.com/index.php?l=doc/data.php
Sierra Chart Support
Date Time Of Last Edit: 2013-10-29 18:05:50
[2013-10-29 18:06:23]
Since most likely you will be using more than one Data or Trading service at the same time, you will want to install 2 copies of Sierra Chart. This is documented here:
http://www.sierrachart.com/index.php?l=doc/MultipleServices.html
