Date/Time: Wed, 22 Jan 2025 18:20:18 +0000
Can the Last Trade Price Box be hidden?
View Count: 914
[2018-10-15 18:27:57] |
infpz - Posts: 826 |
A have a value label I would like to take preference visually.
[2018-10-16 20:26:27] |
No, it is not possible to remove the Last Trade Price from the Price Ladder. Another option that is available is to add the Value Label column to the Chart DOM and then place the Value Label you are interested into that column. The documentation for adding the column is here: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) The documentation for placing the Value Label in the Label column is here: Chart Studies: Subgraphs Tab >> Name and Value Labels And, if you are not using the Chart DOM, here is the documentation for how to turn on the Market Data Columns: Trade Menu: Show Market Data Columns (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-16 21:36:53] |
User90125 - Posts: 715 |
Can't seem to find the Chart/Trade DOM options in v1822 64-bit (build 24679:24680) to fully customize the columns. Please advise.
[2018-10-16 22:04:00] |
You need a direct Sierra Chart account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
