Date/Time: Wed, 22 Jan 2025 18:23:29 +0000
Sierra chart data feed connection problem
View Count: 641
[2018-10-15 18:02:08]
User169693 - Posts: 7
Getting an error msg that Sierra isn't responding......then charts go white and forced to close progrm.
I don't think it's even trying to connect to the data feed.
Any suggestions?
[2018-10-15 18:36:16]
We recommend starting with a new Chartbook. Refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook
And also update Sierra Chart to the current version following the instructions here:
Date Time Of Last Edit: 2018-10-15 18:36:33
