Date/Time: Wed, 22 Jan 2025 18:17:08 +0000
Global symbol settings
View Count: 939
[2018-10-15 15:49:32] |
User734334 - Posts: 6 |
Good evening, I have a question about global symbol settings. I have changed Trade/Quote symbol - see atached file - but when I change the symbol on a chart (Find Symbol - Change Chart Symbol) , then in Trade and Current Quote Symbol in chart settings is nothing. I always must click Apply Global Symbol Settings. Where I do mistake, is there any solution? Kind regards. Stanislav |
global settings.PNG / V - Attached On 2018-10-15 15:48:03 UTC - Size: 127.46 KB - 260 views |
[2018-10-15 17:38:15] |
We are looking into this. We are making some changes which should resolve it in the next release.
