Date/Time: Wed, 22 Jan 2025 18:10:36 +0000
Risk Reward Tool Config is buggy
View Count: 782
[2018-10-15 12:30:36] |
jsmanuse - Posts: 32 |
After setting the font for the Risk Reward tool, it goes to a 182 point size regardless of font or saving the default. Thought you might want to know. http://www.sierrachart.com/image.php?Image=1539606376515.png |
riskreward tool config is buggy.PNG / V - Attached On 2018-10-15 12:29:49 UTC - Size: 33.96 KB - 279 views |
[2018-10-15 18:31:54] |
This will be resolved in the next release.
