Date/Time: Wed, 22 Jan 2025 18:19:10 +0000
chartdom background depth
View Count: 672
[2018-10-15 01:42:52] |
Bedhog - Posts: 179 |
Hello All, I need help locating the chartdom background color. I'd like the color to be sized with the depth as opposed to the same size background or just a black background. Thank you. |
like-this-dom-ask-bid-depth.JPG / V - Attached On 2018-10-15 01:40:46 UTC - Size: 26.2 KB - 302 views not-like-this-dom-ask-bid-depth.JPG / V - Attached On 2018-10-15 01:40:53 UTC - Size: 29.91 KB - 276 views nor-like-this-dom-ask-bid-depth.JPG / V - Attached On 2018-10-15 01:41:02 UTC - Size: 27.86 KB - 279 views |
[2018-10-15 15:33:09] |
John - SC Support - Posts: 37376 |
There are two settings you need for this. The first is to turn on the Volume Bars for the depth. This can be found on the Trade >> Customize Chart Trade DOM Columns. Refer to the documentation here: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) The second setting is for the color of the Volume Bars in the Bid/Ask columns. These are found under Global Settings >> Graphics Settings - Global >> Chart DOM Bid Volume Bar/Chart DOM Ask Volume Bar. Refer to the documentation here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Ask Volume Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-15 16:35:02] |
Solved. Thank you!
Show-Volume-Bars.JPG / V - Attached On 2018-10-15 16:34:09 UTC - Size: 39.18 KB - 282 views |
