Date/Time: Wed, 22 Jan 2025 20:50:52 +0000
Volume By Price - Suggestion
View Count: 892
[2018-10-14 23:58:28] |
Tony - Posts: 549 |
Right now, under "Time Period Type for 'Fixed Time'", there are "Minutes, Days, Weeks, Months, Years, Seconds", it would be great if "Sessions" can be added to the list. Thanks! |
[2018-10-15 01:02:11] |
If you describe what you want as the end result we will tell you how to configure it. There should be no reason for us to add this.
[2018-10-15 03:18:10] |
Tony - Posts: 549 |
You are right, These 2 Volume Graph Period Types, "One Period at End of Fixed Time Length" and "One Period at End of Fixed Time Length - Auto-Skip Empty Days", meet my requirement. Thanks for your reply.
Date Time Of Last Edit: 2018-10-23 14:17:45
[2018-10-19 08:06:31] |
We need some time to look over post #3. There would have to be the ability to skip a weekend day.
