Date/Time: Wed, 22 Jan 2025 18:20:48 +0000
Lot tracker for /es
View Count: 1001
[2018-10-14 19:00:22] |
User149226 - Posts: 16 |
Here is a study that FT-71 composed on IRT that takes the amount of contracts per transaction as there coming into the exchange and plots them on a line graph. The yellow line represents 200 or more contracts per transaction (x-large), white line is 28 contracts or more per transaction (large), and orange is 27 and less (small). Is this possible to replicate using sierra? Thanks
lot tracker.jpg / V - Attached On 2018-10-14 18:58:55 UTC - Size: 86.5 KB - 387 views Attachment Deleted. |
[2018-10-14 20:22:51] |
You can do this with this particular study: Time and Sales Volume If you want to display it in Chart Region 1 make sure to set it to an Independent Scale Range: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-14 21:06:23
