Date/Time: Wed, 22 Jan 2025 18:18:52 +0000
Different prices on two charts 2-ticks and 5-ticks per par
View Count: 741
[2018-10-13 09:38:55]
User597042 - Posts: 5
Hello
I have a chart ESZ8 with Range bars (Range per bar - Standard in Ticks), 5 ticks per bar.
I have duplicated it and set 2 ticks per bar on the second chart.
Now at the same time point two charts show quite different closing prices.
For example a 2-tick chart at 10:56:02 shows 2757.25 and
a 5-tick chart at 10:56:02 shows 2758.00
Is it OK? It is a little misleading. How can I avoid it?
Thank you.
imageESZ8-2018-10-13.jpg / V - Attached On 2018-10-13 09:38:43 UTC - Size: 201.72 KB - 286 views
[2018-10-13 16:49:04]
Sawtooth - Posts: 4159
Sierra Chart's bar time stamps are at the Open, not the Close.
[2018-10-14 19:17:39]
We do not see the relevancy of the timestamps here. Our basic answer is explain to us why would they would be the same? What is the relevancy of the time here? Those are not time-based bars. This is why this was marked as a User Discussion.
Date Time Of Last Edit: 2018-10-14 19:17:56
[2018-10-14 19:54:01]
Since these are not time based bars, the close price will not be the same in bars of the same open timestamp.
Date Time Of Last Edit: 2018-10-14 23:55:49
