Date/Time: Wed, 22 Jan 2025 15:51:02 +0000
ACSIL Line...
View Count: 606
[2018-10-12 18:08:00] |
maxpi - Posts: 181 |
I add lines as user drawn and they appear on the chart, i can adjust them, can read all the values, it's just great really. If I close the workspace and reopen it they are not there. Is there a way to retain them through a shutdown?
[2018-10-12 19:28:53] |
Yes. Refer to: Using Drawing Tools From an Advanced Custom Study: s_UseTool::AllowSaveToChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
